Dynamic Signal Acquisition
Finsh a stand alone application
Hi, again I couldn't make this simple appliaction to worka as a stand alone application! it runs nice in the pc I have installed the labview software, but I want to have it as a stand alone application so I can use it in other pc's too; the problem is it runs continuously -
attached is the vi (pretty simple and primitive, regarding progammin but it works for me) if you could add a start stop button so I can build the app!!!
thanks a lot!
Dimitrs
(6,425 Views)
I've attached below a screen shot of how you might incorporate a Stop Button into your application. You currently have your application stopping when the result of NIDSA Get Swept Sine Status.vi is 2. All you would need to do to incorporate a Stop Button is use the OR function; that is, OR the result of your previous setup with a Stop Button, which you can create by right clicking on one of the terminals of the OR function and choosing Create >> Control. Good luck!
Logan S.
(6,425 Views)
