Dynamic Signal Acquisition
Force Displacement
screenshots help the community help you better. Also, if you hover over the broken wire, LabVIEW displays the reason the wire is broken.
I guess the following may help get to a working VI:
Right-click the error indexing tunnel on your For Loops and select Tunnel Mode>>Last Value.
Right-click the build array node and select Concatenate Inputs
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
Message 11 of 13
(2,531 Views)
Hey Doug, here is attached my VI and a screenshot of the project.
As you can see, i copy your last post and conected with the charts I want to see. But now i am not able to measure force and displacement.
Would you be able to help me ? what am I doing wrong ?
thank again.
Message 12 of 13
(2,520 Views)
Enable indexing of waveforms on output tunnels of For Loops.
Doug
Message 13 of 13
(2,489 Views)
