Dynamic Signal Acquisition
Hi is anyone watching here?
Hi is anyone watching here? I really need help
in this vi I don't know why multiply make error
error massege say "LabVIEW:  (Hex 0xFFFFF8F6) Waveforms have different dt values." but both of them dynamic data
please answer me
(7,927 Views)
The sample rate of your acquisition from the computer microphone is currently set at 22,050 Samples per second while the simulated signal sample rate is set at 100,000 Samples per second.  These result in different delta times in the waveform making the multiplication invalid.
To remedy this error both of these sample rates should be the same, I would recommend changing the sample rate of the simulated signal express VI to 22050 to fix the error.
Doug Farrell
Solutions Marketing - Automotive
National Instruments Automotive Solutions
(7,925 Views)
duplicate post
Please do not cross-post, and if you do, please make it know so people don't waste their time answering a question that has already been answered.
(7,920 Views)
I fixed Samples both 44,000 but still not working
and this vi worked before I Insert that multiply thing
I think problem is others but my very little study can't find that
(7,918 Views)
// I'm so sorry I never gonna do that
(7,915 Views)
Doug L. Bear// I fixed again to 100,000 and that is working
Thank you vert much for you answer
(7,912 Views)
