Dynamic Signal Acquisition
Highest measurable frequency for the NI 4551 under the swept sine mode?
(6,893 Views)
The 4551 has a max input (acquisition) signal bandwidth of 95 KHz and output (generation) of 23 KHz. You will find this spec here:
http://www.ni.com/pdf/products/us/3sv417-420.pdf
(6,879 Views)
The swept-sine mode of NI-DSA uses a sampling rate of 51.2 kS/s. The highest frequency that can be analyzed is slightly above 20 kHz.
Thierry
(6,871 Views)
