Dynamic Signal Acquisition
How can I acquire signals in telemetry way?
Dear all,
There are three or four force sensors mounting in a rotating axis, and they need power supply (11-30V, 10mA) as well. Is there any facility in NI can accomplish this project? Or do you have a similar signal acquisition telemetry system in project?
1. get 3 or 4 channels of voltage/current signals from force sensors in  the rotating axis.
2. provide power for components in the rotating axis.
3. provide driving signals to components in rotating axis.
Thank you very much!
(6,777 Views)
Dear Jinghang,
I would have thought our cRIO products would be able to make up the main body of your system.
Deterministic controller and FPGA technology perfect for control applications. Furthermore, there are plenty of high sepc "cseries" modules, each with inbuild converters, amplifiers, signal conditioning and font end connectivity.
For example, we have modules built specifically for accelerometer/force sensors. For example, the following module has inbuilt IEPE signal conditioning and very high performance converters.
https://www.ni.com/en-us/shop/category/sound-and-vibration.html?productId=118141
I would highly suggest giving your local branch a call to discuss your requirements further.
We look forward to hearing from you soon,
Rich Roberts
Senior Marketing Engineer, National Instruments
Connect on LinkedIn: https://www.linkedin.com/in/richard-roberts-4176a27b/
(6,765 Views)
