Dynamic Signal Acquisition
How can I calibrate USB 9233?
The USB-9233 returns uncalibrated binary data. You can apply calibration coefficients and convert the data to engineering units in software.
        By  USB-9233 USER GUIDE AND SPECIFICATIONS  Page  8
" 一天到晚游泳的鱼"
labview@263.net
我的个人网站:LabVIEW——北方客栈 http://www.labview365.com
欢迎加入《LabVIEW编程思想》组——http://decibel.ni.com/content/groups/thinking-in-labview
(9,540 Views)
How to calibrate USB 9233?
" 一天到晚游泳的鱼"
labview@263.net
(9,532 Views)
This is actually an error in the documentation of the USB-9233.  The DAQmx driver does return calibrated, scaled data from the device so you don't have to do this yourself.  Sorry if this caused any confusion.  We'll get this fixed, thanks for pointing it out.
-Jack
(9,515 Views)
Jack
I need to calibrate USB 9233.
How can do it?
jwdz
" 一天到晚游泳的鱼"
labview@263.net
(9,506 Views)
The USB-9233 comes already calibrated from the factory when you purchased it.  Currently, we do not have a calibration procedure in Calibration Executive for performing a detailed calibration on the device.  If you want, you can send the USB-9233 to NI to have a basic calibration done.  For more info on calibration, check out: http://www.ni.com/calibration
FYI, in the calibration list price doc (http://www.ni.com/pdf/support/us/calibpricelist.pdf), the USB-9233 falls under the C Series module section.
Hope this helps,
Jack
(9,490 Views)
Jack.A
Thank you very much.
It is expensive.
jwdz
帖子被jwdz在03-14-2006 07:28 PM时编辑过了
" 一天到晚游泳的鱼"
labview@263.net
(9,485 Views)
