Dynamic Signal Acquisition
How to connect PCB 352C34 peizo acclerometer to NI9219 module of NI Crio 9082
How to connect PCB 352C34 peizo acclerometer to NI9219 module of NI Crio 9082?
the cable consist one earth shielding and one input point,
(4,897 Views)
The sensor is a ICP resp. IEPE type. You need a constant supply current in a range of 2mA to 8(?)mA.  You DAQ doesn't directly support this type of sensor.
You need a IEPE capable DAQ or you build or buy a IEPE supply (J-FET plus resistor and a 24V supply)  with decoupling (470µF /36V Capacitor)
Greetings from Germany
Henrik
LV since v3.1
(4,866 Views)
Devices such as NI 9234, NI 9218, NI 9250, ... support direct connectivity to IEPE sensors.
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
(4,864 Views)
