Dynamic Signal Acquisition
How to converse the array of the format int16 to the array of the format binary?
How to converse the array of the format int16 (int32) to the array of the format binary in the program LabView 6.0.1? Whether is present in the program LabView 6.0.1 to map the raster (raster graph) from an output of the demodulator? If yes, how?
(6,166 Views)
Converting from decimal format to binary is all in the representation. You can right click on a control or indicator and select "format and precision" and change the format to binary. Now the 132 data is represented in a binary format. I am not sure it this is what you were looking for, but there you go.
(6,165 Views)
