01-03-2008 10:35 AM
01-04-2008 08:36 AM
Hello SirMutt,
I'm sure that you can do this with the 6541, as it has per-line direction config. I believe it uses the HSDIO driver, though. You might find the section here down where it says "Interfacing with Digital Devices" helpful...
However, I don't have much experience with DIO, so I would suggest that you post to the Digital I/O forum here
http://forums.ni.com/ni/board?board.id=70
that way you can get the full benefit of the "community" since digital gurus will be monitoring these forums ![]()
Good luck!
-gaving
01-04-2008 09:18 AM
