Dynamic Signal Acquisition
How to save signals
what is the easiest way to save 6 signals (1-D array of double, length limited = 30sec) in a file and for loading later in labview of course. I want to use it also with diadem.
thanx
cand. dipl. inf
Vedran Divkovic
RUB
Germany
(6,206 Views)
Diadem can inport an ASCII format, tab delimited file. I would suggest the easiest solution is to combine the 6 x 1-D arrays (assuming they are of the same length) into a single 2-D array. Have the data transposed to column-major order (data in columns) and use the "Write to Spreadsheet File.vi"
(6,206 Views)
