Dynamic Signal Acquisition
How to synchronizes analog input with analog output
Hi, there,
Does somebody know where I can find an example to synchronize analog input and output in VB? Thanks in advance.
Yingmai
(6,807 Views)
Hello Yingmai,
Most National Instruments drivers come with shipping examples. The location of these examples will depend on the driver that your hardware uses. For most analog input/output devices, the driver is NI-DAQmx. To determine if your hardware uses NI-DAQmx you can view the Data Acquisition (DAQ) Installation/Configuration Troubleshooter and navigate to the device you are using.
If your device is compatible with NI-DAQmx, you can find installed example programs on your computer here: C:\Program Files\National Instruments\NI-DAQ\Examples. The examples should be sorted by development environment. Additionally, this page discusses examples for Visual Basic specifically.
Similar examples are available for other drivers as well. I hope this information is helpful, let me know if there is anything else I can do.
Matt Anderson
Hardware Services Marketing Manager
(6,789 Views)
