Dynamic Signal Acquisition
ICP quartz force ring work with 9232
Hallo,
I am trying to acquire low frequency force measurements,
for this I am using ICP quartz force ring (model 202B) the specifications attached.
The question is can I use 9232 with DC coupling to accomplish the measurements?
Thank you in advance.
(6,615 Views)
Hey Manos76,
I have looked through the specifications for the device and the card, and the 9232 will provide the proper signal conditioning through excitation voltage and current for the device to function.  The DC coupling will allow you to read the devicve.
I hope that helps!
J Newk
Systems Engineer
(6,597 Views)
Hallo J Newk,
Thank you for your reply.
It is really helpful that I have a confirmation before the ordering of the module.
Best regards
Manos Smyrnaios
(6,585 Views)
