Dynamic Signal Acquisition
In which version of DAQmx can I find AI.EnhancedAliasRejectionEnable property?
I have the NI PXI 4472B. I work at the acquisition frequency of 1024Hz. I have seen (in Dynamic Signal Acquisition Help, chapter 'Low-Frequency Alias Rejection') that between 1 kS/s and 25.6 kS/s, the anti-aliasing filters of DSA device AI channels may not completely reject all out-of-band signals. To resolve this problem, one way is to enable low-frequency alias rejection with the AI.EnhancedAliasRejectionEnable property.
I have the DAQmx 7.5 version, and I did not find it. It should be on the node property of DAQ Create Channel. So, I would like to know which version of DAQmx has this property.
Thanks a lot,
ben
(6,677 Views)
Bonjour,
Vous trouverez ci-joint l'endroit où trouver la propriété "AI.EnhancedAliasRejectionEnable" dans la classe DAQmx Channel (fait avec NI-DAQmx 7.4). Attention, cette propriété n'apparaît que si le matériel le supporte.
Title: Low Frequency Alias Rejection with a 447x Device
Problem: Which revisions of my 447x boards support low frequency alias rejection?
Solution : Presently, the following PXI devices support this feature:
PXI-4472 rev H and later
PXI-4472B rev H and later
Cordialement.
Matthieu G.
National Instruments France
(6,663 Views)
