Dynamic Signal Acquisition
Is it possible to generate sine sweep of frequencies 0.1Hz,1Hz,2,3,4.....100Hz.
Sl.NoFrequency
1     0.1Hz
2     1Hz
3      2Hz
4     3Hz
5      4Hz
100  99Hz
101  100Hz
(6,465 Views)
The Sound and Vibration Toolkit API allows you to easily configure standard and custom sweeps. Here is one configuration implementation Custom Discrete Sweep Configuration.png
that outputs your requested frequencies
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
(6,459 Views)
same code in a snippet that should be more readable here in the forums
Doug
(6,458 Views)
