Dynamic Signal Acquisition
Is it possible to read data from TDC Card using Labview!!
I have a question. Is it possible to use TDC card to read the data through Labview! Currently I am using PCI card for reading the data. I have a program written by someone else which collects the data from PCI card. I need to shift this data input and output from TDC card . Is it possible to do it?
Can anyone help me to solve this!
Maithili
(7,403 Views)
Hello;
I'm not familiar with the TDC DAQ card, but, in case you have the board documentation stating what DLL function calls need to be made in order to execurte a DAQ task, you can use the Call Library Function of Labview to execute the functions.
You will need to execute all functions needed to accomplish the DAQ task in a sequence structure, to make the function calls in the necessary order.
Hope this helps.
Filipe A.
(7,403 Views)
Thanks a lot for the help. I will go through the option suggested by you and will get back to you with the results.
Thanks again,
Maithili
(7,403 Views)
I have a question for you. TDC card is a PCI Card. I am looking for its specifications.
Is there any information on writing a driver in Labview to read the data from this card!
Do you have any idea which manual/information I should go thruogh to write such a program!
Thanks a lot,
Maithili
(7,403 Views)
