Dynamic Signal Acquisition
Lock-in Software and NI PCI-4472
I have a need to acquire the signal of 16 individual detectors simulataneously. The idea of connecting the detectors to the computer is as follows:
16 Detectors --> 16 Pre Amps --> 2 NI PCI-4472 boards --> lock-in software on LabVIEW
Has anyone any experience in using the NI PCI-4472 boards with several detectors and parallel lock-in detection? Is it possible to run the lock-in software in parallel to acoomodate several detectors simultaneously?
Martin
(7,132 Views)
Hi Martin,
         I think you might be interested in taking a look at a few examples:   <link no longer exists> and DAQmx and <link no longer exists>. Both of these examples should be a good starting poing for your application,  it should be possible to run the lock-in software in parallel.  Also, have you checked out NI's Lock-IN Amplifier Start-Up Kit? Have a great weekend!
aNIta B
Message Edited by aNIta B on 02-06-2009 01:59 PM
(7,114 Views)
