Dynamic Signal Acquisition
Mating Connector of NI-SMB 110 connector Reg
I am using NI PCI 4551 DSA boards for signal acquisition. Also BNC connector assembly, SMB 110 coaxial cables are used with this board for connectivity. Now, one end of SMB  110 is BNC termination and the other end of SMB 110 cable is terminated with small amphenol connector. I would like to know the part number of this amphenol connector so that I can purchase mating connectors to simply connect my dynamic signals to NI PCI 4551 board inputs.
Kindly provide the required part number on the other end of NI SMB 110 cable.
Thanks in advance,
ADM
(7,394 Views)
I am not sure exactly which device part# are you looking for
smb connector on smb 110 is a regular smb connector. It is a IREX-510 cable. You contact the manufacturer IREX if you need further info.
Also you can get similar connector from
Johnson Components: part # 131-3701-531
http://www.johnsoncomponents.com/
Kalyan
Kalyanramu Vemishetty
Automated Test Systems Engineer
(7,378 Views)
