Dynamic Signal Acquisition
Measurement error from NIDSA_get_olm_status() function
(Before anyone asks, yes, we've read the function help page in NidsaC.hlp :))
We have a legacy product that uses an PCI-4552 DSA card.  We have a section of code that runs like this:
ViStatus dsaStatus;
ViStatus newMeasurement;
dsaStatus = NIDSA_check_new_measurement(dsaSession, &newMeasurement);
// Error checking removed for clarity
if ((dsaStatus == 0) && (newMeasurement))
   dsaStatus = NIDSA_get_olm_status(dsaSession,
                                    dsaChannelNumber,
                                    &elapsedSeconds,
                                    &linearAvgCompleted,
                                    &measurementError,
                                    &overload,
                                    &rt_error);
if (dsaStatus == 0)
   // log the status of any of the arguments to
   // NIDSA_get_olm_status() callthat did not return 0
The logs from this system report several cases where the measuremenError value is 1 *and* the overload value is 1.
Does an overload condition always trigger a measurement error condition?
If dsaStatus returned 0, what other things might be causing measurementError to be non-zero?
Thanks!
--Peter
(6,212 Views)
Hi Promba,
Yes, an overload condition will always trigger a Measurement error condition becuase an overload in a type measurement error. You can check the manual, page 4-10 to see what will cause a measurement error.
Matt
(6,188 Views)
