Dynamic Signal Acquisition
Microphone Array Average
I am using a PXI-4462 and a PXI-4461 to simultaneously aquire 6 microphone readings.  I would like to average the readings from each microphone and then display the average using the tools in the LabVIEW sound and vibration tool kit.  Essentially make all six readings look like one.  I have tried several different methods but the results are not what I expected.  I've attached a copy of my current vi which seems to be reading and averaging but it appears that somewhere data is lost.  Any suggestions?  Thanks.
LabVIEW 2016 - Windows 7
CLAD
(6,930 Views)
Hi MeCoOp,
I took a look at your code and I believe what you are missing is the connection between the SVT Fractional-octave Analysis VI's Octave Info Ouput and the SVT Build Result Table VI's Octave Info Input. I put some simulated signals into this VI and once I made the connection described above, I was able to see all of the data in the table.
Message Edited by Jordan D on 08-27-2007 10:13 PM
Jordan D
Applications Engineering
(6,906 Views)
