Dynamic Signal Acquisition
On a NI USB 4432 device, any C++ APIs, to interface with module from C++ application.
1.C++ API - Can I interface with the NI USB 4432 by means of a C/C++ application, does it have C/C++ api or dll. Need to get the input/signals from the module in a C/C++ application . 2.Compatibility - OS Information, is the product drivers Windows XPE (XP Embedded) compatible? 3.Any link/site to the full documentation on the module
(6,614 Views)
Accepted by topic author CPlusDeveloper
You should use the NI DAQmx driver
http://www.ni.com/dataacquisition/nidaqmx.htm
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
(6,611 Views)
The datasheet on the NI USB 4432 is not that clear.
E.g. the datasheet on the NI USB 6009 specify the following:
Requirements and Compatibility
OS Information
Windows 2000/XP
Mac OS X
Windows 7
Windows CE
Windows Mobile
Windows Vista x64
Windows Vista x86
Driver Information
NI-DAQmx
NI-DAQmx Base
Software Compatibility
ANSI C/C++
LabVIEW SignalExpress
LabWindows/CVI
Measurement Studio
Thanks, I will try NI-DAQmx.
(6,607 Views)
