Dynamic Signal Acquisition
PCI-4461 Temperature Issue
  I am concerned about the temp. of the 4461 card in my PC, the specification of the card says that the normal operating temp. is 0 to 50C, when i checked the temp. on MAX under the current temp. It's 49C! my room temp. is around 22C, i also assume that when the card starts working and generating signals the card temp. will go even higher! any thoughts on this please.
Omran
(7,684 Views)
Hello techtak
That information MAX displays is not the current temperature, it is the last self calibration temperature.
Self Calibration >> Last Self Calibration Temperature
Your card might be working under 50C, you could perform another self calibration at a lower temp if you want.
Regards
Frank R.
(7,656 Views)
I would also suggest cleaning your fan filters if you have them.
(7,653 Views)
Hello Frank,
   Thanks for taking the time on this, in fact there is a current temp. monitoring in MAX as you see the attached pic. and the temp. does change depending on the environment around, but I have to restart MAX every time to see the change in temp.! i opened the PC cover and directed a small cooling fan on the card and the temp. dropped down to 40C in few minutes, with the cover open and without a fan the temp only went down to 47 from 49!
(7,636 Views)
Hello techtak
You are right, that one is the current temp. You should assure its functionality under 50C.
Getting the Current Temperature in Measurement & Automation Explorer (MAX) for Your Device.
Regards
Frank R.
(7,629 Views)
In MAX, the only thing you should need to do to update the current temp is hit the Refresh button in the toolbar.  I test this using MAX 5.5 and DAQmx 9.8 as a reference.
(7,617 Views)
Thanks Joshua, I also realized that I can refresh by hitting F5,
(7,613 Views)
