Dynamic Signal Acquisition
Problème de stabilité et de précision de mesure de tension sous MAX
My goal: To acquire a voltage output by an LVDT.
While using a multimeter or an agilent I have a measuring accuracy of the order of 5mV.
Otherwise, using two different cards: PCI 6013 or 6014 + CB68LP terminal and different ways (test on two different PCs):
The MAX test panels give me an accuracy of the order of 100mV! Therefore impossible to obtain sufficient accuracy with the LVDT.
Big noise, but where does it from??
Conf. Labview 2010, DAQmx 9.2.2
Help !!!!!  Smiley Surprised
(5,780 Views)
Duplicate
Samuel G. | GEMESIS
Certified LabVIEW Architect
Certified TestStand Developer
GEMESIS.EU
(5,765 Views)
