Dynamic Signal Acquisition
Problems with execution of software trigger in a ni-9233 module on C-rio 9104
Hi, i'm creating a project for vibration measurements of 4 accelerometers with c-rio 9104 and Ni-9233 module. I need to execute a trigger event (start the signals acquisition when signal crosses a trigger level). Few time ago I used NI- 9233 module with USB connector and I found an exemple that was perfect for my application (<link no longer exists>). Now I tried to modify this VI for make it compatible with FPGA system but SW_trig VI doesn't work. I thought I have a problem when I call FIFO in SW_trig VI because I called it in the Host VI.Is it right? I need help
MATHB
below i listed VIs screenshots
(6,607 Views)
Thanks for your post.  FPGA and CompactRIO add some great capabilities, yet we also need to think about them a bit different.
To make things easier, we developed this reference example, which we ask you to consider:
http://zone.ni.com/devzone/cda/tut/p/id/9196
For the trigger - a tachometer for example, we also have a trigger VI that can be used in FPGA
http://zone.ni.com/devzone/cda/epd/p/id/2326
For the RT side, our Sound and Vibration Measurement Suite also has tachometer trigger VIs and angular alignment VIs that might be helpful.
Let us know if these are useful.
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
(6,606 Views)
