Dynamic Signal Acquisition
Provide NIDSA_read_measurement() API argument details ?
My Requirement is to do Frequency Response (i.e. calculate Gain (-3dB value) and Phase (90 Deg value).
Steps Followed:
1. I am using NI 4551 (DSA) for this Frequency Response Test
2. I am able to send command like start frequency, stop frequency and Amplitude
3. I am able to getting Frequency Axis like command using NIDSA_read_measurement API, but i am unable to read data like Gain and phase values.
4. I think there is problem with passing arguments to that NIDSA_read_measurement API.
5. Kindly send those correct passing arguments to that NIDSA_read_measurement API.
6. Only problem wiht reading gain and phase values.
(6,568 Views)
Sateesh,
Information regarding the NIDSA_read_measurement function and other NI-DSA functions can be found in Start >> All Programs >> National Instruments >> NI-DSA.  There you will find the NI-DSA Help for C programmers document and NI-DSA for BASIC Programmers.  I hope this helps.
Lon A.
(6,553 Views)
