Dynamic Signal Acquisition
RTSI pinout for the PCI NI-4472 DSA
What is the RTSI pinout for the 4472 DSA?
Sebulba
(8,070 Views)
Sebulba:
RTSI pinouts are the same for any PCI card.  See the KnowledgeBase article below for details:
Hope that helps!
Todd S.
Todd S.
LabVIEW Community Manager
(8,056 Views)
Hi Todd,
Ah, yes, I found this information before posting this question. However, I have some problems with the documentation. When I check the “Device Routes” tab in MAX for the NI-4472 I see RTSI8 and RTSI9 in addition to the lower channels.
RTSI8 and 9 do not appear in the RTSI pinout table in the document to which you refer. Also in that table there is mention of RTSI_OSC which does not appear as a signal in the table in MAX. Could you please clarify?
Sebulba
Message Edited by Sebulba on 03-17-2006 02:14 PM
(8,052 Views)
Sebulba:
Sorry for the delayed response.  As far as I can tell, and I've confirmed this with others here in our department, those RTSI lines have not function for the 4472.  This could mean one of three things:
1)  They exist to allow for possible future possible expansion of the firmware for the 4472
2)  Since they appear in MAX, and if they have a green color next to their name, you can use them to send data across the different PCI-4472's you have.
3)  They are internally used for oscillation/timebase signals.
Please let me know what you need to do.  If they impact your design I'd be happy to investigate further.
Todd S.
Todd S.
(8,021 Views)
Thanks for the reply, Todd S.
So it looks like I have been monitoring the proper line on the RTSI connector. I am basically just trying to figure out a way to get a clock signal on one of the RTSI lines to synchronize three DSA cards. I wanted to monitor the line to make sure that things were working as I thought (a bottoms-up approach.) The complication is that I have to do this in MATLAB and I would like to use as much of the functions in the data acquisition toolbox as possible. But as I dig deeper into this problem I am seeing that the data acquisition toolbox goes not allow to sync two cards.
Sebulba
(8,013 Views)
