Dynamic Signal Acquisition
SVT Octave calculated 1/3,1/6,1/12,1/24
Hi all
   I want to calculated octave by SVT Fractional-octave Analysis.vi.when Select 1/3 octave out data is right,and other 1/6,1/12,1/24 out data are different,if somewhere was set wrong.Please help me check it,thanks in advance!
(7,485 Views)
Hi all
   who can help me for that,I want use this octave to generator different sweep sine waveform,It's a appreciated for you help anymore.
(7,429 Views)
Yes, the midband frequencies are different between 1/3 octave and 1/6 octave bands. Refer to Section 5.4 of IEC 61260-1-2014 for the formulas. The SVT VI is returning the correct nominal frequencies for each fractional octave bandwidth according to the standard.
As a specific example, let us examine the nearest band to 20 Hz.
Full octave: fm = 15.85 Hz, f_nom = 16 Hz
1/3 octave: fm = 19.95 Hz, f_nom = 20 Hz
1/6 octave: fm = 21.13 Hz, f_nom = 21.1 Hz
1/12 octave: fm = 20.54 Hz, f_nom = 20.5 Hz
1/24 octave: fm = 20.24 Hz, f_nom = 20.2 Hz
In the note right below the formulas, IEC 61260 also states:
NOTE 1 The outputs of narrow-bandwidth fractional-octave-band filters that have exact mid-band frequencies
determined from Formula (2) or Formula (3) can be combined to approximate the band level indicated by a filter of
wider bandwidth with a corresponding exact mid-band frequency and corresponding band-edge frequencies.
Looking again at 1/6 octave bands, now let us investigate just below 20 Hz:
1/6 octave: fm = 18.84 Hz, f_nom = 18.8 Hz
and we could combine the two 1/6 octave bands around 20 Hz to capture exactly the same band as the 1/3 octave band centered (nominally) at 20 Hz.
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
(7,414 Views)
