Dynamic Signal Acquisition
Synchronization between Analog Output and Input
I am using NI 4551 (DSA card)and using NI-DAQ APIs for writing and reading throch Analog Channels. As I am writing and reading the data I am getting a delay of 18mSec at the input channel.How can I avoid this delay and synchronize Analog Output with Analog Input.
(6,789 Views)
It seems most likely that you are seeing the filter delay that is inherent in the device because it uses delta-sigma converters. To read more about this delay look at page 3-8 in the NI 4551/4552 User Manual linked below:
https://www.ni.com/docs/en-US/bundle/321934a/resource/321934a.pdf
Hope this helps!
Brian Spears
(6,763 Views)
