Dynamic Signal Acquisition
The avi creator is creating files, but with 0kb. What's wrong?
With the data acquisition equipment we are mesuring the pressure profile of an airbag deployment. Almost everything works fine except creating the avi file. From the chronic:
In the creating procedure of the avi menue your latest activity is to select the "Full frame uncompressed" button . Now the system is creating frame by frame of the avi as usual without an error message. Then the system is storing the avi file to your selected directory also as usual, but with 0 kb.Normally this file, it depends on lenght-recording, has approx. 30MB. The system cannot find the link to the file. It is storing something, because the drive c:capacity is going up. So I've tried everything , no result. Can you give me suppo
rt. Thanks.
(6,511 Views)
Have you tried the AVI example - if so - does that work? I am assuming that you do see the file being created. Do you have any sample code that you can post? Make sure that the images that you are writing are not empty images.
(6,511 Views)
