Dynamic Signal Acquisition
What is the best way to save sound signal data?
I have the NI USB-9233 DSA interface with labVIEW 8.5 and the Sound and Vibration Toolkit Version 5.0.  I am aquiring a sound signal from a microphone at a sample rate of 50k.  My goal is to save this data to a file in such a way that I can reload it to run comparitive Power Spectrum FFT and octave band plots. The duration of the recording time could be anywhere from 5 sec to 30 sec. What is the best format to save the data in, ASCII, WAV, UF558?
Scott
Message 1 of 8
(9,785 Views)
Hi Scott,
There certainly are a number of ways to store your information. Since the files you are writing are not especially large (2-12 Mb), you don't have to be too concerned with file size. I recommend using the following two example files used to write and read .WAV files.
SVXMPL_WAV Recorder (DAQmx).vi
SVXMPL_WAV Power Spectrum.vi
These examples can be found in the LabVIEW's Example Finder under
NI Example Finder » Toolkits and Modules » Sound and Vibration » File Input and Output » ...
Jordan D
Applications Engineering
Message 2 of 8
(9,768 Views)
I've looked at the wav recorder and my concern starts within the sound write waveform vi.  I know the vi is scaling the signal, but I can't follow exactly what's it's doing.  When I've tried to step into the vi, I've been only able to step over it.  I've attached a word document with a picture that points to where I'm getting lost.  Basically, I don't mind if the signal is scaled/amplified, but I do need to know what that gain is and that it need is constant test to test so that when I start comparing tests, I know how to scale it to decibel units.
Scott
Message 3 of 8
(9,761 Views)
Hi Scott,
You are correct in thinking that the AI Max/Min are taken from the front panel of the Wave Recorder VI. These values are passed into the task inside the svx_DAQmx Get Info VI. There isn't any scaling performed in this VI. Keep me posted if you have more questions.
Jordan D
Message 4 of 8
(9,736 Views)
I don't have it installed apparently so I need the sound and vibration toolkit. Does that cost money and how do I install it.
Message 5 of 8
(8,898 Views)
Hi Oli Oli Oxin Free,
Here is a link to the Sound & Vibration Product page.  It is not free.  On this page there is a link to evaluating the software which will guide you through the installation process.
If you would like I can get you in touch with a sales representative about purchasing this.
Please let me know if you have further questions!
Sincerely,
Jason Daming
http://www.ni.com/support
Message 6 of 8
(8,882 Views)
You can evaluate the Sound and Vibration Measurement Suite 7.0 for 30 days before making a purchase. During the evaluation period, the evaluation license allows full use of the product. We would appreciate your feedback and, hopefully, your business Smiley Happy.
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
Message 7 of 8
(8,876 Views)
I have read somewhere that WAF does not maintain the gain of the signal. I am not sure about this, but maybe you should be careful there.....
Seems that TDMS is a preferred file format for dynamic signals. I have only very recently started to use it with LV 8.6, but is seem to be quite useful.
Cheers
Gerd
Message 8 of 8
(8,487 Views)
