Dynamic Signal Acquisition
When do I need a dynamic signal acquisition board instead of a 'standard' DAQ ?
The question is in the title: When do I need a dynamic signal acquisition board instead of a 'standard' DAQ ? (The other question behind it is: what is a 'dynamic' signal exactly ?)
Thank you in advance,
Julien
(8,425 Views)
Hi Julien,
Most MIO devices use a multiplexed architecture for multi-channel acquisitions.  In these setups, an analog MUX “moves” the ADC rapidly from one channel to the next.  Because the individual channels are not sampled at exactly the same time, this introduces an artificial phase delay when signals are compared between channels. Simultaneous sampling between all channels is a requirement in high-speed applications that involve Digitisers.  The reason for this is that phase between channels is important for Digitiser applications and can only be measured accurately when all channels are simultaneously sampled.  Digitisers, DSA, and S-Series DAQ products use separate ADCs per channel to achieve a tight phase relationship between channels.
Dynamic Signals are those in which you wish to examine the spectral (frequency-domain) content using analysis such as power / phase spectrum, octave analysis, order analysis, frequency response. Examples include sound, vibration, power consumption, and signal level.
Hope this helps,
(8,424 Views)
Thank you very much. That is very clear.
Best,
Julien
(8,421 Views)
The DSA boards (such as the 9233 and the 4472) also provide anti-aliasing built in as well as a very wide dynamic range (24bit ADCs).  These two features are essential for vibration, acoustics, and rotating machinery applications.
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
(8,406 Views)
Thanks a lot !
Julien
(8,363 Views)
I want to know, too!
(8,278 Views)
