Dynamic Signal Acquisition
When using NI scope Error -1074101997 occurred
I use NI scope, but I often report an error of -1074101997,and Possible reasons for 'The reuqested data has been overwritten in memory so it is no longer available for fetching'.I use it for multi-channel data acquisition.Someone has the same problem as me?Thanks!
(4,824 Views)
Hello, could you please let me know what kind of hardware do you use?
(4,754 Views)
Hi,NIRest.I'm using PXIe-5171R.And I've solved this problem by use IDLs.Thank you.
(4,748 Views)
