Dynamic Signal Acquisition
Why is THD higher than SFDR in specification? Why is the SFDR Test done with a -60dB Signal?
NI Hardware: Multifunction DAQ device USB-9211
The following questions arise in the decision making process regarding a 24bit-  or 16bit - ADC for acceleration measurements on a gearbox
Why is the  THD value higher than the SFDR in the specification? The harmonics are excluded for the SFDR measurement?
Whats about a 0dB or -3db sine tone? I expect the SFDR will be much lower.
(11,761 Views)
Hello Mr Hinrichs,
Could you please give me more detailed information’s, about where you found this data’s about THD and SFDR. I had a closer look to the specifications of the USB-9211, but I couldn’t find any information in the user manual  USB-9211/9211A User Guide and Specifications Are you sure, you named the right devices in your post?
I’m waiting for your response, so we can go further with this issue
Kind regards
Ulrich Möschel
Application engineer
(11,658 Views)
sorry, must be usb-9233
(11,632 Views)
Total Harmonic Distortion is the sum of distortions over a frequency range.
Spurious Free Dynamic Range is the maximum spur across a frequency range and is not related to harmonics as harmonics are a multiple of the frequency.
More can be found here:
https://www.ni.com/docs/en-US/bundle/ni-scope/page/spurious-free-dynamic-range.html
THD Should always be greater than SFDR as THD is a sum of harmonics whereas SFDR relates to one specifically which is the maximum across a spectrum.
(6,930 Views)
Yes, harmonics are often excluded from SFDR measurement, and that appears to be the case in the published specifications for the 9234.
With a 9234 input, at a test level of 3.5 V pk (-3.1 dB ref 5 V), I consistently measure SFDR to be 112 dB or better.
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
(6,924 Views)
Generally, there is no set relationship between THD and SFDR. If you have a case where you are including harmonics in SFDR and the max spur is a harmonic of the test frequency, then |THD| <= SFDR.
Doug
(6,923 Views)
I refer to the 9234 in my responses because that is NI's current recommended 4 Ch, 24-bit, c-Series device.
Doug
(6,918 Views)
