Dynamic Signal Acquisition
Will DAQ with PCI-4474 and a Kinemetrics Episensor ES-U sensor work?
We are planning to setup a DAQ system measuring some low level vibration. The system considered will be a PC based card, PCI-4474 and a Kinematrics Episensor ES-U accelerometer. Before purchase,we would like to find out is there any compatibility issue between these two devices or any complicacy in setting them up. Suggestions are welcomed. Thanks.
(8,336 Views)
Based on the datasheet for the sensor, it seems that it would be a great fit for the PCI-4474, especially when using the +/- 10 V output range of the sensor. This would maximize the use of the large dynamic range of the 2 products.
(8,336 Views)
Hi Zenz,
I just want to ask how is your project going regarding the PCI-4474 and a Kinematrics Episensor ES-U accelerometer. I am using the same model of accelerometer from Kinemetrics but now it's power by an old ADC from Kinemetrics also. Now were planning to shift to NI DAQ including the power supplies. Were more on vibration testing.
Sherwin
Philippines
(7,440 Views)
