Dynamic Signal Acquisition
applying input voltages
Hi all
I would like to apply input voltages that are collected and put them in my array based on the position of where the measurement was taken.  Right now I can collect the input voltages and I can control the position on the array where they go.  I am having an issue with taking multiple readings and applying each new reading to the new position in the array.  I have tried wiring it directly in to the array and it does nothing unless I stop the voltage reading and then I only get the last reading filling the array.   Next I tried to make a local variable and use this variable to add to the array and this yield nothing as well.  Right now I am runing out of ideas.  Over all I am trying to fill out the intensity graph.  I attached the vi and the part I am talking about is on the right side.  Thanks
(6,887 Views)
I figured it out about a hour after I posted this.  Thanks anyways.Smiley Very Happy
(6,883 Views)
