Dynamic Signal Acquisition
drivers for I/O Tech Daqbook 200?
I'm trying an eval. copy of LabView, and want to test it on my DaqBook200. What do I have to do to get drivers for the hardware?
Will the eval. copy do frequency spectrum FFTs?
(6,583 Views)
Since the DAQ device that you are using is not a National Instruments product, you will have to contact I/O Tech and request the drivers and the LabVIEW support files so that you can call the board directly from LabVIEW.
Regarding the FFTs, you should not have any problems programming your application using analysis VI's, even though the LabVIEW software that you are using is an evaluation version.
Good luck with your application!
(6,583 Views)
