Dynamic Signal Acquisition
error code -61073 nirio: fifo read, Why Am I Getting Error -61073 When I Run my Host VI for LabVIEW FPGA?
Am I Getting Error -61073 When I Run my Host VI for LabVIEW FPGA.
Please let me know how to debugg this error.
Error and status message : error code -61073 nirio: fifo read
Vedha
Message Edited by vedha on 12-04-2007 03:15 PM
(10,906 Views)
I'm not familiar with RIO (as it's not what I work with) that much, but the error code's definition seems to be pretty easy to understand.
http://zone.ni.com/reference/en-XX/help/371599A-01/lvfpgahost/fpgainterface_error_codes/
You might think of posting in another forum, possibly the LabVIEW one http://forums.ni.com/ni/board?board.id=170 to get some more exposure.
Good luck!
Gavin Goodrich
Software Engineer
(10,899 Views)
Thank you,
very much gavin. that was the fastest feedback i ever got.
Thanks a lot,
Vedha
(10,892 Views)
The answer looks like the information that I need. This is the only return when searching for "ERROR code -61073." Sadly the link is dead!  😞
(8,453 Views)
I had the same problem.
The solution is simple. Memory reserved for the data was too small in relation to their counts. Parameter "depth" must be greater than "number of elements".
(7,638 Views)
