Dynamic Signal Acquisition
how do i print the NI Audiomasters result vector to an excel file or a text file
How can I print the reslut vector uin Audiomaster to an excel file?
(6,163 Views)
Hello cparekh,
In order to extract the information from a result vector, you will need to use a post expression to copy the result vectors to a local variable at the end of each step. The reason for this is that TestStand makes a copy of the context tree when executing the step so the results are erased by default when the execution ends. This makes it difficult to configure limits, etc. because it isn't immediately possible to view the results while editing the limits.
The result vectors can be found in the location shown in the picture below:
Jim St
RF Product Support Engineer
(6,133 Views)
