Dynamic Signal Acquisition
how i can generat VHDL or Verilog code from labview code
how i can generat VHDL or Verilog code from labview code ( i have a labview code and i want to convert it to VHDL or Verilog code how i can do that )
(10,302 Views)
Mouath,
There is no feature in LabVIEW to export your VIs as VHDL files. You are able to include your own HDL in your LabVIEW VI (using the HDL node). I encourage you to provide your feedback related to this issue at ni.com/contact. The product suggestion submitted are taken seriously and reviewed by National Instruments.
Cheers,
Jonah
Jonah Paul
Marketing Manager, NI Software
(10,294 Views)
Hello mouath,
I have the same problem: I want to genrate the vhdl code from labview. Did you find a solution??
Thanks in advance.
(7,136 Views)
NI currently does not offer a method to obtain the VHDL code from the LabVIEW FPGA code. Also I would like to recommend you to please create a new thread for your questions, instead of posting on a thread that was created so long ago.
Ricardo A.
(7,113 Views)
