Dynamic Signal Acquisition
how to configure digital tacho in SVMS using PCI-6143?
hi all,
i am trying to develop a shaft vibration monitoring system using S&V meas. suite7 and labview8.6 contains polar graph; program attached with few emendmends to NI DSA example.
problem is that how to configure digiat tachmeter using  6143 counter as i want to have 4 analog continuous inputs (NCDT) along with the counter edge counting info (continuous) for digital tacho processing to caculate phase.
when i defining the counter task for  edge counting continuously.... it ask for an external clock to configure with, which is problem. how can i do this project with one board 6143 with digital tacho.
anyone would emend this code to execute with 6143.
thanks
Masood
(6,372 Views)
This is a duplicate post.  The discussion can be found here.
Gary P.
(6,356 Views)
