Dynamic Signal Acquisition
how to set the microphone sensitivity in SVXMPL_WAV recorder (DAQmx)
when I record the sound using the captioned VI, I can not find how to set the sensitivity.
Any advise will be great appriciated.
(6,491 Views)
Hi Actro,
      I believe you should check out the information in this post, as it explains why you're not seeing that functionality.  As well, one thing you could try would be to create a DAQmx Channel property node and us the property Analog Input»Sound Presssure»Microphone»Sensitivity.
(6,485 Views)
