Dynamic Signal Acquisition
increasing the time resolution of VI logger
Dear All,
I want to increase the time resolution of the "hyper trend cursor" in VI logger software. Its maximum resolution is 1ms. It cannot go below this. How can I increase the time resolution, I know the simple way is the inverse to frequency, but I have to do these calculations often, I want a better solution. There is a pulse shown in the attachment, the width of the pulse is less than one milli-second. what can I do.
thank u.
Munir
Research centre Juelich
Germany
(6,698 Views)
Hello Munir,
unfortunately, it it not possible to set a higher resolution in VI Logger.
Depending on your application, you might need to use LabView for a more flexible signal display.
Johannes
(6,688 Views)
