Dynamic Signal Acquisition
is NI 9234 compatible with DeltaTron®?
Hello, I have recently purchased Binaural Microphone-Type 4101 and the
product data sheet specifies that it should be connected to a
DeltaTron® input (3 to 10mA). My doubt is if it is compatible with
IEPE standard since I want to connect the microphones to a NI 9234
signal acquisition module that has an IEPE constant current source of
2mA.
Best regards.
Mariano Araneda
Centro de Investigación y Transferencia en Acústica (CINTRA)
UA del CONICET - UTN, FRC
Maestro M. López esq. Cruz Roja Argentina
(X5016ZAA) Córdoba, Argentina
Tel/Fax: +54 351 4686389
(5,991 Views)
As you can see at the link below, it is compatible.
http://forums.ni.com/t5/Dynamic-Signal-Acquisition/measure-sound-power-and-sound-intensity-with-NI-U...
Thanks.
Best Regards
Luciano Borges
Test Development Engineer
(5,967 Views)
