Dynamic Signal Acquisition
on-board multifunction DAQ programming ?
I need to make the following sequence a certain number of times : generate a pair of voltages (from a list, or computed from the loop index), make a pause, and finally measure some input voltage.
As I cannot rely on the timing of my VB program (either too slow, or erratic)  to make this step by step, I would like to program this directly on some board, buffer the measurements and, once the measurements are all completed, transfer them to the application.
Which is the best way, and least expensive way to do this, using a (multifunction DAQ) NI card ?
thanks
(7,196 Views)
P.S. I have seen there are ways to obtain hardware signal generation and acquisition with the X series multifunction DAQs. However, it is not clear to me how one can obtain both functions in a synchronized way ?
(7,185 Views)
Hi Ornito,
Would you like to program it with LabVIEW and DAQmx drivers? Or other software?
You can have a look on the Getting Started of DAQmx, you will find out some basic programmation tips and other helpful informations : https://www.ni.com/en/support/documentation/supplemental/06/getting-started-with-ni-daqmx--main-page...
Indeed, multifunction DAQ card will fit your application and you need to know what is the expected range from your measurements.
Do you have any precise limits (price etc)?
You should contact the sales service of National Instruments in your area, they will be able to suggest some products according to your needs.
Celine
National Instruments France
(7,174 Views)
Hi Celine,
I preferably use Visual Basic. But we could also make some executables using LabView, if really needed. We do not have strong sampling rate requirements, so I was thinking of NI PCIe-6321 for instance. I just want tomake sure that buffered input and output may be both used in the same sequence. I will certainly contact my local representative - thanks
(7,172 Views)
Hi Ornito,
NI PCIe-6321 should fit your needs.
Nevertheless, if your local representative can suggest others products, it's better for you in order to have a largest view for your application.
Celine
(7,169 Views)
