Dynamic Signal Acquisition
pxi-5105 THD measurement
Can the NI PXI-5105 digitizer be used to perform a THD measurement on ~ 1KHz signal using the LabViews Sound and Vibration toolkit?  Is the Sound and Vibration toolkit required or is it just a nice to have feature that makes life easier?
(6,484 Views)
Hi Bob,
Have you seen this example? http://zone.ni.com/devzone/cda/epd/p/id/6181
It uses NI-Scope and the Sound and Vibration Toolkit to perform a THD measurement. This sounds like what you are looking for. The Sound and Vibration Toolkit has the required VIs that perform the measurement.
Aaron
(6,475 Views)
Hi Aaron, yes, I saw that article.  I got together with my LabView developer and we simulated a 1 KHz square wave and sent it through a simulated 1 pole 2 KHz low-pass butterwoth and a simulated 3 pole 2 KHz low-pass butterworth.  We used the analysis tools included with our developer suite edition and in both cases we got a very good THD measurement, 5% for the 3 pole filter and 19% for the single pole filter.  I can't remember what LabView tool we used, I can get it from the delevoper if anyone is interested.
Bob French
(6,472 Views)
