Dynamic Signal Acquisition
state of 4472b after reset device
I'd like to know which is the state or parameters configuration of the 4472b device after being reseted. For example, if I reset the device programatically and then perform a measurement indicating, let's say the samplig rate and length, but nothing about the ICP. Which state would the ICP for the measurement?
Greetings
crimolvic
(6,404 Views)
Hey crimolvic,
The state of ICP should be "off" after a device reset, and you should be in DC mode.
(for any channel you configure and use)
Good luck,
-gaving
(6,396 Views)
