Enhanced Icon Editor
[Bug] Template in LabVIEW 2009 SP1
Hi Tom
I am having an issue with templates and 2009 SP1.
I load up code from 2009 which has a template in it, and the Icon Editor moves my text!
The text was in the banner (which is what I want) now it is moving it below
Have you seen this/ can you replicate it?
Was there any change in LV2009 SP1?
Or is it something else?
Here is a video link demonstrating the issue: http://www.screencast.com/t/MzUwMTAyMTUt
Cheers
-JG
Certified LabVIEW Architect * LabVIEW Champion
(6,200 Views)
Yeah I guess I know where that one comes from.
I believe that you use the icon editor as out of the box in SP1 without having the bug fixes installed that I posted a while ago here
The unmodified icon editor doesn't take templates into consideration if the template is smaller than 32x32.
Once you have installed the modified files, everything should work as expected.
Since users may have noticed this bug in the past and used the workaround by manually drawing the rectangle as you did, I don't need to be worried about backwards compatibility either.
Let me know if that works for you.
Tom
(4,733 Views)
Sorry, I assumed that the new files would have been included in SP1 so never tried the patch.
Just installed the patch and it that looks like its fixed it!
Cheers
-JG
(4,733 Views)
