Enhanced Icon Editor
Icon Editor in Executable
I am currently writing a simple tool which will be used by LabVIEW developers and want to include the Icon editor as part of the build.  However it seems it seems that the NI Icon editor does not like being built into an executable.  I ma using the "Launch Icon Editor.vi" from the AP but it wont allow me to load the fron panel.
I am thinking this is by design from NI but can someone confirm this is the case or give me a hint on how to do it if possible.
I am guessing the only other option is to launch it via a LabVIEW application reference and run it in the development environment.  It was just preferable to embedd it in the exe as we run lots of different labview versions and setting the port for VI Server is doable but a bit of a pain.
Craig
LabVIEW 2012
(6,347 Views)
There is a fair bit of functionality in the Icon Editor that is not supported in the run-time engine. Unfortunately for your use case, the icon editor was not designed to be built into an EXE.
(6,341 Views)
Thought as much,
Thanks for letting me know Darren.
Craig
LabVIEW 2012
(6,338 Views)
