Enhanced Icon Editor
small font size 9 doesn't work
i am using windows XP, LabVIEW 2009.
why can't i use "small font" and size 9 with Icon Editor, the text shows not clear?
but size 11 look fine.
(13,006 Views)
I just tested and mine is all good on Win7 and XP.
In fact font size 8 and 9 are no different.
Can you test it on a different PC/install
Also do you have the upgrade patch installed?
Cheers
-JG
Certified LabVIEW Architect * LabVIEW Champion
(10,520 Views)
yes i did install the upgrade patch, but it still doesn't help.
also i did try with another PC with WindowXP, it doesn't work too.
i'm not sure about the system font in my PC and another PC....
(10,520 Views)
What version of LabVIEW are you using?
I checked on LV2009.SP1
(10,520 Views)
Unfortunately it hasn't anything to do with LabVIEW, but the OS itself.
Check out this link:
http://forums.ni.com/ni/board/message?board.id=170&message.id=460177#M460177
(10,520 Views)
Thank you very much for everyone....
(10,520 Views)
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019ZTFSA2&l=en-US
You can use the small fonts by editing LabVIEW.ini file.
(8,387 Views)
