Example Code
2-Edge Analog Level Separation
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
The example Demonstrates how to achieve 2-edge analog separation on a card when the counters are not available, or the signal is not TTL
Description:
Attached is code to achieve 2-edge analog separation on a card when counters are not available, or the signal is not TTL.  Please note that the code require the first signal in the scan list to reach the analog level.  Originally the second signal expected was a digital signal, which is why the control is labeled digital level.
Steps to implement or execute code
To implement this example:
This assumes that the analog signal is the first channel in the scan list, and the analog level is reached before the digital pulse comes.
  1. Set the physical channel to be used
  2. (Optional) Define the rest of the parameters as needed
  3. Run the VI
  4. (Optional) Turn on the Highlight Execution to see the flow of the VI
To execute this example:
  1. Install the required software.
  2. Connect the DAQ hardware that supports the Analog Input features
  3. Confirm the connection with the MAX with TestPanel
  4. Open the VI and refer the Implement Steps
Requirements
Software
LabVIEW 2012 or compatible
NI-DAQmx 16.0 or compatible
Hardware
cDAQ with C series Analog Input Module
Adam
Academic Product Manager
National Intruments
