Overview
A power supply gui used to control the Keithley 2306
Description
The 2306_GUI.vi is the top level vi. It is an event driven power supply. Change control:Hopefully all the vis and typedefs are here now. If there are any still missing let me know.thanks
Requirements
Software
LabVIEW 2012(or compatible)
NI-VISA
Hardware
Keithley 2306
missing typedef
typedef and subvi's missing so no use at all
missing typedef
For output two "Select multiple for VDC #2" typedef I was using a typedef from my 2304a power supply and did not include it in the zip file. I should have used the same typedef for output one "Select multiple for VDC #1". I have updated the zip file and the gui. According to my vi hiearchy all the vis and typedefs should be there now. If you still have issues let me know.
